Vga to HDMI Problem,Becomes high Contrast and Text Shades, How to Fix?
If it worked fine with a DVI to VGA type that comes with you graphics card/PC, you can get a DVI to VGA cable in stead, it will do the same ting, but don't use that much space.
You will find them cheap on ebay, with free shipping.
EDIT: I tried to look up your monitor. It seems to have a 1600x900 resolution. Have you put the windows resolution to this? Some HDMI outputs might only support HD resolutions like 1280x720 and 1920x1080. If you have this resolution in Windows, the text will be as you describe, since the monitor will have to upconvert or downconvert. But I believe the GTX 760 you say you have will handle the 1600x900 resolution.
But can I urge you to save up to a new monitor, any cheap 1920x1080 monitor with DVI or HDMI input will automaticly give you readable text. I can garantee you that it won't be any worse that it is today.
