ok so i'm looking to buy another zotac GTX 780ti, but my friend has had a lot of problems with his 570 sli config (constant crashes and wierd colours on screen) so is problems with sli something that happens to a lot of people or have the things i've been hearing wrong?
https://linustechtips.com/topic/213509-is-sli-problems-a-common-thing/
SLI And Crossfile is a bit finicky and doesn't always seem to work properly you should be fine. If anything goes wrong try swapping the cards and making sure your drivers are up to date. Its honestly really strange the way SLI works but you should be fine.
Sli problems arnt nearly as bad or frequent as they are made out to be, but they do exist
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
afaik, SLI problems exist because game devs do a crap job of supporting sli/crossfire or just outright don't support it.
I don't think it's nearly as much of a problem as it was before, considering how many high end pc's use sli 780ti's (meaning that the performance gains far outweighs the problems that sli introduces)
Home is where the heart my desktop is.
had sli, got crossfire now..........had very few problems with either of them.
----Ryzen R9 5900X----X570 Aorus elite----Vetroo V5----240GB Kingston HyperX 3k----Samsung 250GB EVO840----512GB Kingston Nvme----3TB Seagate----4TB Western Digital Green----8TB Seagate----32GB Patriot Viper 4 3200Mhz CL 16 ----Power Color Red dragon 5700XT----Fractal Design R4 Black Pearl ----Corsair RM850w----
