Build a PC, doesnt turn on! PLEASE HELP
Hei, today  I build my first Pc folowing this guide:
So I finished building it and tryed to turn it on for the first time. All the fans are running, all the lights are on, but my monitor sais no signal when i plug it in and is point black. Anyone has any idea what could be wrong?
components:
INTEL Core i7-4790K, 4x 4.00GHz, boxed
WD Black 1TB, 4KB Sektoren, SATA 6Gb/s
KINGSTON 16GB 1866MHz DDR3 CL10 DIMM
COOLER MASTER CM 690 III
MSI Z97-GD65 Gaming (7845-002R
SAMSUNG 840 Evo Series 250GB SSD SATA3
EVGA SuperNOVA NEX750G 750W ATX 2.3
MSI GeForce GTX 780 Ti Gaming 3G, 3GB GD
- Cooler master hyper 212 evo
https://linustechtips.com/topic/213410-build-a-pc-doesnt-turn-on-please-help/
First, did you try booting it out of the box?
Second, I can't see the part above your cooler, did you plug the 4/8pin connector for the cpu?
Third, is your PSU plugged in/ON
Fourth, Is your computer plugged in an outlet that is dependant on a wall switch?
EDIT: Derp, I read that your computer did not turn on and only read that. :P
As the others said your monitor doesn't seem to be plugged in your card
Hei i fixt it, there was still some kind of plastic on my gpu and when i took it off it works! But now that it started up and i got into bios I have foun another problem...  When i urned it on my hd started ticking and it doesnt appear in the bios. I can see my SSD but not my HD. Its all pluged in correctly . Anyone knows waht it could be?
lol, so you sticked in your graphics card with the plastic sleeve in the bus? I cringed. Hope your board is okay.
Anyway, click in hard drive bbs priorities, it'll show up.
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
Hey there, I am sorry to hear about your issue.
I would suggest that you check the cabling once again - the HDD's power cable and the SATA cable.
Another thing you could do is check what HDD mode is activated in the BIOS. In storage configuration menu in the BIOS make sure the SATA drive is not set to IDE but to AHCI.
Hope this helps.
Cheers, Dorian_WD
Western Digital Representative
http://www.wdc.com/en/
