I plan on selling my GTX 760s ( MSI GTX 760 OC Gaming Edition) soon, I was wondering what kind of prices people are throwing them out for them these days.
Both GPU1 and 2 are stable at 1290mhz with a memory clock of 6950mhz
I was thinking $175 or $300 for both, but I haven't been in the used GPU market for so long I wouldn't know what a good price is for these.
https://linustechtips.com/topic/213352-gtx-760-advice/
I if i was buying a used one i would probably spend no more then $75 just because it used and there is no longer a warranty and stuff sooooo yea. Just mean though you can probably get a lot more the $75
https://linustechtips.com/topic/213352-gtx-760-advice/#findComment-2910094
selling graphics cards is hard, right now i wouldnt even consider that card if im being honest, but i would probably list them as said by @AlwaysFSX , seems pretty reasonable considering one of those cards new would run you 300 after taxes, so its essentially getting the second one for 50.
https://linustechtips.com/topic/213352-gtx-760-advice/#findComment-2910177
