that can search based on a-like images? I used to have this profile pic someone made for me from a game a long I played a while back, and it was awesome and I want it.
Thanks for any help!
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
https://linustechtips.com/topic/212828-is-there-a-search-engine/
use google reverse image search and it will show you images that look similar.
Well I need to find the image to begin with, all I have is a screenshot of it. IDK how to do that either.
https://linustechtips.com/topic/212828-is-there-a-search-engine/#findComment-2890185
Try to crop the screenshot and only leave the pic, then click the little camera icon that's on the Google Images search bar to look for similar images.
i'm a potato
https://linustechtips.com/topic/212828-is-there-a-search-engine/#findComment-2890194
Why not upload the screenshot here and see if anyone knows what it is that you are looking for?
https://linustechtips.com/topic/212828-is-there-a-search-engine/#findComment-2890231
aight m8.
I did the reverse search, the majority of what popped up was womens clothing.
https://linustechtips.com/topic/212828-is-there-a-search-engine/#findComment-2890249
