Hello all I was advised from my friend after he bought his parts that he had an MSI B85 G43 mobo with an i5 4690K and I told him that the CPU isn't supported and to sell his board, ignoring my advice he went ahead and build his sytem the GPU he had is an r9 280x 3GB and 8 GB ram and on ultra 1080p he gets 40-60 frames and I aassume this is from the compatibility . please help thanks harry
https://linustechtips.com/topic/212547-compatibility-problem-please-help/
They are compatible, just probably not the best combo as he has an overclocking chip and a board that can not overclock
CPU: Intel Core i5 4460 | GPU: XFX r9 280x DD BLACK OC EDITION | RAM: 8gb Kingston HyperX Fury 1600Mhz | Mobo: Gigabyte h97n-WIFI | PSU: EVGA 600B | Case: Cooler Master Elite 120 | Cooler: Stock intel | SSD: Samsung 840 EVO 120gb | Storage: WD 150 gb
CPU: Intel Core i7 4710MQ | GPU: NVIDIA Geforce GTX 850M | RAM: 8gb Corsair 1600Mhz | Mobo: Metabox WA50SJ Motherboard | Case: Metabox WA50SJ case | Cooler: Stock | SSD: Sandisk 256gb
:wub:  :wub:  :wub:
Best purchase this year, bcuz forza
what compatibility ? it works fine also in what game?
Need more information.  What game is he playing that is getting these results?  Are all drivers for the GPU up to date?
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
Well, you are wrong - these parts are compatible, only on B85 he or shop should have made BIOS update for full compability.
Without BIOS update it could not work on full, but there are more things to consider - temps, PSU, faulty HDD.
Intel i7 2600 @ 4.2 Ghz | MSI Z77-GD55 | Crucial 16 GB DDR3 RAM 1600Mhz | Intel 330 SSD 180Gb | Western Digital Black 1Tb | Western Digital Green 2Tb | Gigabyte GTX 650 Ti | OCZ ModXStream Pro 500W | Thermaltake Commander MS-I case | OS X Yosemite | Dell Vostro 3550 Windows 10
Intel Xeon 1230 V2 | Gigabyte GA-H61M-S | Kingston 4Gb RAM 1333Mhz | Seagate 1TB  | Fractial Design Arc mini | Windows 10
They are compatible, just needs the latest BIOS - check the motherboard manual for how to flash the BIOS Oh nvm - but that 40 - 60 fps on ultra is normal, have you seen the benchmarks?
The most common result of insufficient wattage is a paperweight that looks like a PC
Okay so the game is bf4 and hr has updated the bios but since its a devils canon chip I assumed he needed a h97 or z97 board and idk he may not have the drivers because i had an R9 270 and i5 4690 and I got 70-113 frames on ultra so idk I'll ask him if he has the drivers
Both resolutions for his setup and mine are 1080 p
Thanks guys for your help
His power supply is 500w and I told him he needs 850w 80 plus gold as a minimum
he doesnt need 850w. i am running a 280x on a 650w. i Would say a decent 550w would do him justice, or a very high end 500w
I refuse to read threads whose author does not know how to remove the caps lock!
— Grumpy old man
Well good thing your friend didn't follow your "advice"
CPU Intel i7-4770k @4.4Ghz Motherboard ASUS Maximus VI Hero RAM Corsair Dominator Platinum 1866Mhz 16GB GPU MSI GTX 970 GAMING 4G Case Corsair 760T Storage Samsung 840 EVO 250 GB + 2x WD Black 1TB PSU Corsair AX860 Display(s) AcerXB1, QNIX QX2710                         Cooling Corsair H105 Keyboard Corsair K70 Cherry MX Red + Red LED Mouse Logitech G700s Sound Beyerdynamic MMX300
I came to the community for your advice other wise he would have followed my advice -_- I needed more information on what could be done and if what I was on about was right or not clearly it wasn't that right and you learn something new every day
