Hi guys,
A friend of mine's 660 Ti (Asus) got dripped on by a H100i and may be dying/dead.
He had it develop graphic issues and eventually shut down the computer while gaming before he realized that gunky water/coolant has dripped onto the card.
I have done my best to clean off the gunk with isopropyl alcohol after disassembling the card (see pic for current status).
It seems to be clear now, but it's still not working (has graphics issues, see the pic)
Any advise before I just shelf the card???
Cheers.
UPDATE:
Baked card at 200 celcius for 7 minutes, card is working now by the looks of things (YAY)
Pics of the baking and card operating in games.
https://linustechtips.com/topic/212544-reviving-a-dyingdead-gpu-help/
But for real, I am not sure, just thought of this video
Main PC: CPU: i7-4770k RAM: 16GB Kingston HyperX Blu SSD: Samsung 850 Pro 256GB HDD: 1TB WD Blue GPU: ASUS GeForce GTX 770 2GB PSU: Corsair CX600M Case: Bitfenix Shinobi OS: Windows 10 Pro 64-Bit
Laptop: ASUS N56VJ
I hope someone would provide further details if the oven would actually help.
PS I've never soldered anything, so that could be troublesome.
Doesn't corsair provide some kind of replacement program when things like this happen? They're suppose to replace the cooler and affected components, you might wanna look into it
The most common result of insufficient wattage is a paperweight that looks like a PC
See, now I can't take that seriously......normally, yes, demonic, no.
Now that I've seen Linus' video, it might be worth a try.
Please man
Should of read the spoiler, I said "for real, I don't know how to fix your problem"
Laptop: ASUS N56VJ
I've used a heat gun on a failed MacBook Pro GPU.
Main Machine:  16 inch MacBook Pro (2021), Apple M1 Pro (10 CPU, 16 GPU Core), 512GB SDD, 16GB RAM
Gaming Machine:  Acer Nitro 5, Core i7 10750H, RTX 3060 (L) 6GB, 1TB SSD (Boot), 2TB SSD (Storage), 32GB DDR4 RAM
Other Tech: iPhone 15 Pro Max, Series 6 Apple Watch (LTE), AirPods Max, PS4, Nintendo Switch, PS3, Xbox 360
Network Gear:  TP Link Gigabit 24 Port Switch, TP-Link Deco M4 Mesh Wi-Fi, M1 MacMini File & Media Server with 8TB of RAID 1 Storage
I did read it and I've seen the vid before
ok
Laptop: ASUS N56VJ
  • 2 weeks later...
UPDATE:
I cooked the graphics card for 7min at 200 Celsius and it is now operational without any hickups yet (still a little more testing to do)
Pics included of the baking process, and the computer runing games :) in my first post
