Hello,
I have a shadow rock 2 CPU cooler. I could OC my FX 8320 to 4.6Ghz at 1.4125V at 60C. I am just about to buy a new Intel i5 4690k or i7 4770k (i5=$210 i7=$288) so I want to get a new cooler. My Mobo is a MSI Z97 gaming 7. Is this H100 cooler a large upgrade?
Thanks
https://linustechtips.com/topic/212470-shadow-rock-2-vs-h100/
not really. you will most likely be limited by voltage more than temps but it may be quieter depending on the fans
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
https://linustechtips.com/topic/212470-shadow-rock-2-vs-h100/#findComment-2885331
What cpu and on the i5 (I think that one since its cheaper and gets same performance in games even 5 years from now) it can oc since its devils canyone plus I have a good Mobo, what temp difference should I see and is it worth the $60 it cost me for the H100?
https://linustechtips.com/topic/212470-shadow-rock-2-vs-h100/#findComment-2885338
the i5 will easily be fine for another 3~ years
Specs
https://linustechtips.com/topic/212470-shadow-rock-2-vs-h100/#findComment-2885341
I7? Also what's the cooling upgrade is it large?
no need for the i7 and the shadow rock 2 is a great cooler
Specs
https://linustechtips.com/topic/212470-shadow-rock-2-vs-h100/#findComment-2885359
I just orderd the H100 was that a bad choice? It was $55.
well if you just did no point calcining the order
Specs
https://linustechtips.com/topic/212470-shadow-rock-2-vs-h100/#findComment-2885381
nuttin wrong with the H100, the refurbs are from the older batch of pump noise
(replaced pump/controller) and recouped losses. i used my original H100 for years
till i sold it with the FX rig and it still works like a champ. it'll be better in cooling
ovber the DR2, the newer DR3 it'd be a close match as the H100 has to have the
fans at 50% or less to compete in sound output.
https://linustechtips.com/topic/212470-shadow-rock-2-vs-h100/#findComment-2885398
I can try, is it worth it? How much better is the h100?
look up benchmarks but its fine just use the h100
Specs
https://linustechtips.com/topic/212470-shadow-rock-2-vs-h100/#findComment-2885400
Is it a worthy upgrade?
https://linustechtips.com/topic/212470-shadow-rock-2-vs-h100/#findComment-2885406
temp wise, i've seen as much a 8-12°. with the H100 fans on high perf, could be
more. the middle setting is balanced and good thermal control and not too harsh
on the ears. i believe when i was 1.535v on 8350 and the fans were balanced
temps were 76°ish which most peeps cringe, but no throttling and the CHVFZ
VRM was still warm, but not scalding the 990FXa UD3 was a total disaster in heat.
https://linustechtips.com/topic/212470-shadow-rock-2-vs-h100/#findComment-2885427
What was your oc? Also I would get 10c less?
https://linustechtips.com/topic/212470-shadow-rock-2-vs-h100/#findComment-2885437
5.1 with the 8-pin and 4-pin secondary or 4.9 with just the 8-pin. something with
applying the 4-pin supplemental power raised the heat pretty bad.
you mean 10° less than the DR2? it is possible.
I have the shadow rock 2. H100 is coming in 1.5weeks because I have to go to USA to pick it up. How much less temp from the shadow rock and what oc on the 4690k?
Thanks so far.
https://linustechtips.com/topic/212470-shadow-rock-2-vs-h100/#findComment-2885466
Thanks so far.
dunna know on intel, i mainly use the H100i for intel now. seldom use the D14 or
Megahalems Black any more. even the test bench has the Tt water extreme 2.0.
https://linustechtips.com/topic/212470-shadow-rock-2-vs-h100/#findComment-2885480
Well H100i should be close (-+2C) from the H100... So what oc do you have on what CPU and what temps? Also would it beat the Nh-D14?
https://linustechtips.com/topic/212470-shadow-rock-2-vs-h100/#findComment-2885494
i7-4770k stock fan XTU stress was 80° (A=24°) static volt mode.
undervolt to 1.080v and temps fell to 68° stock fan, mind you.
i7-4770k H100i silent fan XTU stress was 68° (A=24°) static volt mode.
undervolt to 1.080v and temps fell to 56° silent fan (700RPM).
i7-4770k H100i silent fan 4.8/1.45v temps were 82°, final voltage
4.8/1.39v and 74° using the XTU stress 30-min. STABLE.
H100i beat D14 in thermals on 4.8 and comparative on noise (using rosewill
hyperborea fans).
https://linustechtips.com/topic/212470-shadow-rock-2-vs-h100/#findComment-2885524
hyperborea fans).
Thanks
https://linustechtips.com/topic/212470-shadow-rock-2-vs-h100/#findComment-2885785
