Hey guys,
I have a CaseLabs S5, and as some of you know, its 100% aluminum. I need make some screw holes in my S5 to attack a res to the side. My question is how would i go about doing this? Im following
and can i just go from the initial screwing of the small thing from the machine screwdriver to just slowly screwing the final screw i want in?
Or does it not work like that
Or is there any other method?
Thanks!
https://linustechtips.com/topic/212466-mod-help/
Hey guys,
I have a CaseLabs S5, and as some of you know, its 100% aluminum. I need make some screw holes in my S5 to attack a res to the side. My question is how would i go about doing this? Im following http://www.youtube.com/watch?v=tng-40zrUY0 and can i just go from the initial screwing of the small thing from the machine screwdriver to just slowly screwing the final screw i want in?
Thanks!
Personally I'd mark and drill the holes, and use nuts and bolts on the rear to hold it into place giving it more hold especially if the aluminium is thin for tapping threads into, I kind of doubt that though for caselabs.
https://linustechtips.com/topic/212466-mod-help/#findComment-2885262
@legitlegit
depends on what part is needing threads. most of the chassis structure is 0.090"
thick and can hold a decent thread, but for the sheet stuff, you'd need a nut/bolt for
security. 6-32 is pretty handy in 0.090" ally, but can't apply too much torque to the
screw without possible stripping the thread.
https://linustechtips.com/topic/212466-mod-help/#findComment-2885441
