Xiaomi Piston 2 for $25
They are amazing for the price and they smell like chocolate
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
https://linustechtips.com/topic/211978-earbuds-for-40-usd/#findComment-2877443
Bassy sound?
So with school back in swing I find myself in need of some new earbuds just looking for some decent ones around the $40 price point although I do like a pretty bassy sound signature. Any suggestions?
You should check out the Razer Hammerhead. I'm probably gonna get hate, but they have good bass (I listen to Electronic, Dubstep, Electro, EDM etc. so I love bass). They're pretty decent, I love the aluminum housing.
http://www.amazon.com/Razer-Hammerhead-Ear-Music-Headset/dp/B00DYNQR4S/ref=sr_1_1?ie=UTF8&qid=1410233795&sr=8-1&keywords=Razer+Hammerhead
They're a bit over your budget, at $46 on Amazon.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/211978-earbuds-for-40-usd/#findComment-2877444
Soundmagic e10
https://linustechtips.com/topic/211978-earbuds-for-40-usd/#findComment-2877588
https://linustechtips.com/topic/211978-earbuds-for-40-usd/#findComment-2877843
I heard good things about the Soundmagic E10 and also the nuforce NE-600X.
Also for $5 more you can get the JBL J33's which I personally love, review in signature: http://www.amazon.com/JBL-J33-Premium-In-Ear-Headphones/dp/B009IKCEA2/ref=sr_1_1?ie=UTF8&qid=1410297812&sr=8-1&keywords=jbl+j33 cables are a bit heavy but build quality is amazing.
Reviews: JBL J33i   M50s   SRH440   Soundmagic PL50
https://linustechtips.com/topic/211978-earbuds-for-40-usd/#findComment-2882942
https://linustechtips.com/topic/211978-earbuds-for-40-usd/#findComment-2883186
