Hey guys my friend has an 8350 with the stock heatsink and used Arctic Silver 5 as the thermal paste and his temps are wayy better than me and his case has bad airflow. We even monitored the temps through 2 different sensors. He idles around 25c to 30c. At load he's around 50c.
On my build I have a 4790k with a cm hyper 212 evo in push/pull and my temps idle around 30-40c and load are around 65c.
I also used Antec Formula 7 as my thermal paste.
What gives?
https://linustechtips.com/topic/211516-fx-8350-temps/
  1. What are your ambient temperatures?
Are you OC'ed?
What's your voltage?
Have you tried reapplying thermal paste (and using some of his?)?
How to Post Topics, the Right Way / The Ultimate Build Parts List
"4 words. DON'T BE A DUMBASS" ~@Swndlr
https://linustechtips.com/topic/211516-fx-8350-temps/#findComment-2871202
Comparing two completely different CPU's and expecting temps to be one way or another seems pointless. (Voltages and internals of each CPU are different is what I mean) they will never be exactly the same, unless you changed airflow to make them very similar.
If it was two 8350 CPU's in scenario's like you have stated then it's worth discussing, however Intel and AMD CPU's are different beasts in itself, temps may or may not be similar at any given time.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/211516-fx-8350-temps/#findComment-2871231
I see a lot of people claiming this. Whilst I haven't looked in to it much, I see Intel temps averaging higher than AMD temps, despite AMD CPUs running on higher voltages.
You can check the CPU voltages with CPU-Z or HWmonitor. They aren't as accurate as the BIOS voltage (I think), but should at least give us some sort of idea if the voltage is insanely high.
that is because amd does not have temp probes in its cores, but rather in the socket, so it just aproximates core temps, giving lower values.
as you know, fx is rated to operate up to 60C, while haswell is 90? either AMD uses really cheap silicon, or they adjusted the temps to show less, because i have never heard of silicon that starts degrading at 60C...
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/211516-fx-8350-temps/#findComment-2871472
My voltages are .018
https://linustechtips.com/topic/211516-fx-8350-temps/#findComment-2871843
Ai Suite will read from either Socket temp or AMD's Approximate so it wouldn't achieve much, as for voltages assuming you have a decent asus mobo then it will be in the Ai Tweaker panel of the bios you may have to go to advanced mode first.
Ok so there's several. It says Cpu core voltae at 1.056
Cpu cache voltage 1.189
Cpu input voltage 1.792
https://linustechtips.com/topic/211516-fx-8350-temps/#findComment-2874630
Cpu core voltage is your actual cpu voltage
Cache is the cache on your pc voltage and input voltage is the voltage being put into your cpu
for overclocking core voltage is your main focus
https://linustechtips.com/topic/211516-fx-8350-temps/#findComment-2874960
