Location?
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
https://linustechtips.com/topic/211452-help-water-cooling/#findComment-2870153
COOLING:
https://linustechtips.com/topic/211452-help-water-cooling/#findComment-2870174
anyone wanna help me find a good custom loop for 250 and under?
That's not nearly enough for a proper custom loop. Unless your skimping on parts and cutting corners which will ultimately lead to more potential leaks, headaches and more damage than good.
It's also hard to help when you haven't told us of what you want to cool and in what case.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/211452-help-water-cooling/#findComment-2870778
