Hi
I just installed a kraken g10 to my  r9 290.
Now when i try starting a benchmark or a game it just shuts off.
I think it is because i removed the fan from the gpus pcb.
desperate for help
jojo
My setup
CPU i7 4770K 4.8 ghz 1.4V Motherboard MSI G-45z87 RAM 32gb 1600mhz hyperx ram GPU 3x Gtx 780ti Windforce GHZ edition Case NZXT Phantom 820 Storage 64gb SSD and a 500GB HDD PSU corsair ax1200i Display(s) 3x Acer S231HL Cooling h105 8 corsair af 120
https://linustechtips.com/topic/211063-r9-290-fan-problem-help/
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/211063-r9-290-fan-problem-help/#findComment-2864858
Does it shut off instantly or after a few seconds? Install GPU-Z and get a screenshot of the Sensors tab, so we can see if everything is ok. Maybe the VRM is overheating, but not sure.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/211063-r9-290-fan-problem-help/#findComment-2864920
