hi, i'm modeling a whole PC for a case design v2, that i'm desigin for fun, but with practicality in mind, and hopefully, some manufacturer might pick it up..
can someone help me to model a realistic Matx motherboard (since i have no desktop, i have nothing to refrence to,
or even refrence photos would do good
here's my first attempt:
i'm making a rough model currently quickly to show you the second design, so anyone who can help can determin is it worth your precious time, to model a matx board, or maybe just take some detailed photos of the stickers on your power supply/ your SSD(hard drive)/  etc...
https://linustechtips.com/topic/210803-help-with-modeling-a-pc/
So are you just copying the Alienware Area 51?
https://linustechtips.com/topic/210803-help-with-modeling-a-pc/#findComment-2861040
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/210803-help-with-modeling-a-pc/#findComment-2861046
Stupid comment. Ignore
Samung Tab S 8.4
https://linustechtips.com/topic/210803-help-with-modeling-a-pc/#findComment-2861071
Ah...somebody rendered it for you.Forgot his name.
https://linustechtips.com/topic/210803-help-with-modeling-a-pc/#findComment-2861126
The only thing I don't like about this, is how are you going to cable manage
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/210803-help-with-modeling-a-pc/#findComment-2861150
