What do you think about this setup?
          ASUS H81-PLUS       INTEL Core i3-4150 3.50GHz 1150 BOX       HyperX 8GB Genesis DDR3 1600MHz CL9 KIT KHX1600C9D3K2/8GX       ASUS GTX750TI-PH-2GD5 GTX 750Ti 2GB GDDR5 PCIE       WD Caviar Blue 1TB 7200rpm 64MB SATA3 WD10EZEX       BITFENIX Comrade       FSP Hexa+ 500W
https://linustechtips.com/topic/209541-new-pc-need-help/
Umm... The link doesn't show the parts for me, anyways, thanks for your help, I'll stick with the blue team. :)
 Ops my bad... http://pcpartpicker.com/p/Vjd88d thats the link  :blush:
I choose gigabyte becouse they are not as expensive as Asus and they have dual bios so if you want to Overclock in future you can just grab one i5 K model and have fun :D .Do you have anything that you can use from your old PC ? Case ? HDD ?
https://linustechtips.com/topic/209541-new-pc-need-help/#findComment-2844001
I'd rather not get that Z87
Motherboard: MSI B85M-E33 Micro ATX LGA1150 Motherboard  ($69.62 @ Mwave)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card  ($129.99 @ Newegg)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($29.99 @ Micro Center)
Total: $512.55
Generated by PCPartPicker 2014-09-04 12:09 EDT-0400
New B85 mobos also allow OC capability
My current rig for entertainment/gaming: i5 4570 3,2GHz; MSI B85M-E45; ZOTAC GTX760 AMP!; 8GB (2x4GB) by Kingston; Seagate Barracuda 1TB 7200rpm; Corsair 200R, Corsair VS650; Dell U2312HM, Samsung DVD R/W optical drive; CM Devastator; Corsair MM400 gaming pad
https://linustechtips.com/topic/209541-new-pc-need-help/#findComment-2844340
Personaly I'm not fanboy. Where it has to be AMD it is AMD where it has to be Intel it is Intel But in 500 dolars making a core i3 build for gaming just seems wrong... I mean you can play now but what happends in a year ? Dead Rising 3's minimum is core i3... BUT I can understand you IF you want to swap the CPU with newer one in the not that far future...
https://linustechtips.com/topic/209541-new-pc-need-help/#findComment-2857666
