Program for differing audio to different devices
Go to solution Solved by creatip123,
Yep, do-able, just tried this before posting.
Headphone = external DAC = default audio device = game sound
Speaker = onboard audio = set audio output in foobar2k (free) setting to onboard = music
Test played one round of online FPS, no lag whatsoever. I expected some lags, but turned out no lags that I can feel....
which music software are you using?
you could probably set your default audio device to your speakers, and your music software to your headphones depending on your software
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
