Hey do you guys know what part to get if I were to water cool a i7 4790k and a GTX 780 ti? I was thinking of the Swiftech MCP655 for the pump, RX380 Triple Fan Radiator, for CPU block Swiftech Apogee XL, for the compression fitting and the barb I'll get the swiftech ones. I don't know what to get for the rest of the parts though.
https://linustechtips.com/topic/209203-custom-water-cooler/
why?
you could get a second 780ti instead...
https://linustechtips.com/topic/209203-custom-water-cooler/#findComment-2839081
You should try the swiftech h220-x and a gpu block
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/209203-custom-water-cooler/#findComment-2839371
It sounds like you already got most of the parts, you just need a GPU block, fans, and tubing
For GPU blocks, I'd tell him to get the one he thinks looks the best. Make sure you read up on the installation procedures before you purchase though. Some companies (Aquacomputer) use thermal paste on the RM modules. I don't know if they do that for all their blocks, but they certainly do that for their 290/X blocks.
For fans, you should pair them accordingly to your radiator. it looks like you'll have thick low fin density fins, so you should find fans that perform well at lower rpms (around 1000 or less). Corsair and noctua make pretty good fans, but noctuas are quite expensive. You can try looking at the Rosewill Hyperborea, which are a rebranded Akasa Apache. Silverstone makes good radiator fans too, and I believe Gelid wings and noiseblockers. I'm not too familiar with most of the fans.
For tubing, I like PrimeFlex Advanced LRT. I believe linus has a video about it.
https://linustechtips.com/topic/209203-custom-water-cooler/#findComment-2841803
