Ok, So I have this for now and I need tips on how to get it better for a slighty higher price/less
I'm in Canada so watch out for the price difference :P
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($245.90 @ DirectCanada)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($27.98 @ Newegg Canada)
Motherboard: MSI Z87-G43 Gaming ATX LGA1150 Motherboard  ($109.99 @ NCIX)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($86.99 @ Memory Express)
Video Card: MSI Radeon R9 270X 2GB TWIN FROZR Video Card  ($214.98 @ Amazon Canada)
Case: Zalman Z11 Plus HF1 ATX Mid Tower Case  ($64.99 @ Memory Express)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($49.99 @ Canada Computers)
Total: $800.82
Generated by PCPartPicker 2014-09-02 19:19 EDT-0400
https://linustechtips.com/topic/208758-first-build-planning/
Memory: Kingston XMP Blu Red Series 8GB (2 x 4GB) DDR3-1600 Memory  ($79.99 @ Memory Express)
Video Card: Club 3D Radeon R9 280 3GB royalKing Video Card  ($219.99 @ NCIX)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($58.99 @ NCIX)
Total: $807.83
Generated by PCPartPicker 2014-09-02 19:23 EDT-0400
a club 3d card is going to be better than a 270x. there is better ram for cheaper, and put more into the power supple.
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/208758-first-build-planning/#findComment-2832852
Total: $800.82
so basicly you want better parts ? whats your max budget ?
https://linustechtips.com/topic/208758-first-build-planning/#findComment-2832853
I don't really know my max budget for now but it won't go over 850-900 so for now I took something for 800$
allright. wich part of quebec are you from ?
https://linustechtips.com/topic/208758-first-build-planning/#findComment-2832878
Quebec City :D
ok avan que je continue a prendre des pièces... veut tu du storage ? ou tu en a deja ?
sinon pour une meilleur performance. si le build est bleu. c'est ok ?
https://linustechtips.com/topic/208758-first-build-planning/#findComment-2832914
You didn't mention any storage so to be safe I threw in a 1TB drive
Edit : MrLegendQC Took out the storage upgraded the PSU to a nicer one and put in an after-market cooler.
CPU: Intel Core i5-4570 3.2GHz Quad-Core Processor  ($199.99 @ Memory Express)
Motherboard: ASRock H97 PRO4 ATX LGA1150 Motherboard  ($79.75 @ Vuugo)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  ($84.79 @ DirectCanada)
Video Card: VisionTek Radeon R9 280X 3GB Video Card  ($249.99 @ NCIX)
Total: $792.48
Generated by PCPartPicker 2014-09-02 19:46 EDT-0400
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/208758-first-build-planning/#findComment-2832971
You didn't mention any storage so to be safe i threw in a 1TB drive
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($54.97 @ DirectCanada)
Total: $784.47
Generated by PCPartPicker 2014-09-02 19:39 EDT-0400
I already have storage if you want to remove it :)
https://linustechtips.com/topic/208758-first-build-planning/#findComment-2832979
J'ai mon disque dur de laptop de 1TB ça va suffire anyway jmen fou si il est lent je suis habitué :)
voila. j'ai parcontre changer ton case car la carte graphique etais un peut trops longue :/ sinon j'ai mi un processeur amd FX-9370 qui sera un bon apu mixé avec la r9 280x. :)
http://ca.pcpartpicker.com/p/2QhsVn
https://linustechtips.com/topic/208758-first-build-planning/#findComment-2833161
Laptop hdd are usually 5400 rpm. Not ideal for a desktop system drive. To squeeze in an ssd I had to change the color scheme. It would be nice to go with a better psu. But the budget will not take it.
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($88.00 @ Vuugo)
Memory: Kingston Black Series 8GB (2 x 4GB) DDR3-1600 Memory  ($79.99 @ Memory Express)
Storage: Sandisk Solid State Drive 128GB 2.5" Solid State Drive  ($58.86 @ DirectCanada)
Video Card: Sapphire Radeon R9 270X 2GB Dual-X Video Card  ($209.00 @ Canada Computers)
Case: Zalman Z12 Plus ATX Mid Tower Case  ($59.99 @ Memory Express)
Total: $819.71
Generated by PCPartPicker 2014-09-02 21:13 EDT-0400
https://linustechtips.com/topic/208758-first-build-planning/#findComment-2833593
Total: $819.71
Why is it not ideal ?
If it's for speed idc
https://linustechtips.com/topic/208758-first-build-planning/#findComment-2833844
