Is cleaning thermal copound a must?
Solved by bradscoolio,
If it's temporary and you don't have any methylated spirits, acetone (essentially nail polish remover), or isopropyl alcohol then you go ahead and just wipe it off with a paper towel to get the bulk off then use a microfiber cloth to get it out of micro-scratches :P Your temps will be fine in the mean time, just relinquish all cpu overclocks ;)
Featured Topics
Ianesz ·
Posted in Troubleshooting0 -
Reacher9046 ·
Posted in Build Logs0 -
Donut417 ·
Posted in Storage Devices5 -
d-hubs ·
RYB-Michael ·
Posted in Storage Devices4 -
BLUEEKILLER ·
Posted in Graphics Cards3
