Hello,
Greetings,
Today My pc shut down without a warning and now whenever i try to switch it on the power button led switches on for about 0.2 seconds then nothing happens.the fans are off but i am getting power on my usb wifi card,the card's led is on,when i unplug my pc and drain the power using the power button the card's led switched off,which is a good sign because that means that wifi card doesn't have an inbuilt battery.
I changed the power cable,cleared the CMOS,checked the front panel connectors but nothing happened.and the cpu IS NOT THERMAL TRIPPING because max temp was 76°c after 3 hours under 100% load on all cores
Please help.
Thank you.
https://linustechtips.com/topic/208596-pc-not-starting/
Sounds like a broken PSU or broken motherboard to me. If it doesn't even boot to the Bios and fans do not spin then you either have one of those 2.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/208596-pc-not-starting/#findComment-2830283
Can i like repair the psu?
I need an expert to guide me here.
You run the risk of killing yourself trying to repair a psu and killing your components. Just buy a new one, it's a better solution.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/208596-pc-not-starting/#findComment-2830336
try removing and changing around the ram-sticks. try out another psu and if nothing helps (and i don't believe in wizardry but it worked more than 2 times) just unplug the psu, take out the cmos battery and let it sit for a day. ( ik its blackmagic but try it)
        wow... pretty empty here...
https://linustechtips.com/topic/208596-pc-not-starting/#findComment-2830343
@scaryjam823 just tell me how to fix it because it's 11pm here in india so i cant buy a new 1 and i realy want to game right now.
Seriously, if you don't know anything about it you don't even need to mess with it. It wont be a simple quick fix, nor an easy one. You're better off buying a new one when you can. You aren't going to just fix it in 5 minutes with no parts needed. You need to know enough to see what actually went wrong, replace the part and know what your doing. The capacitors pack enough voltage even when off to kill you. Do not mess with it.
https://linustechtips.com/topic/208596-pc-not-starting/#findComment-2830521
