H75 making buzzing noise after re-seat
Solved by airdeano,
the H75 uses the plastical backplate (Asetek) with small threaded sleeves.
it is possible to have the mount jacked on one/many sides applying awkward
pressure on the cold plate/pump. makes sure the threaded sleeves are fully
seated in the back plate and the backplate is not warped (should be flat and
not riding on the socket plate).
Featured Topics
DudeSquad11 ·
Posted in Troubleshooting0 -
Gnoxis7 ·
Posted in Phones and Tablets2 -
Mr_Roboto ·
Posted in General Discussion3 -
1
8
zombiepunk10 ·
Posted in Console Gaming2 -
1
