Computer making buzzing noise after re-seating cpu + gpu
By
AyoItzYu
in Troubleshooting
in Troubleshooting
Solved by AyoItzYu,
You could try isolating them. Take out the GPU, see if there is noise, and power the GPU without plugging the connectors.
I narrowed it down to the h75 pump. Do you know if reseating it again will fix it ? or do you think I should contact corsair ?
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
14
1
voltigeurramon ·
Posted in Troubleshooting2 -
2
