I recently built my first computer and the wifi speed that it is getting seems WAY slower than it should be. I have a macbook pro that gets 120 Mbps download and 23.3 Mbps upload as determined by speedtest.net, but from the same location my new gaming PC gets just 25 Mbps download and 2.6 Mbps upload. I put a TPI-Link TL-WDN4800 PCI-express wifi adapter <http://www.newegg.co...N82E16833704133> in the PC, and its supposed to get up to 450 Mbps.
I installed the drivers for the card and I've run both the windows diagnostic/repair utility and the TPI utility but I can't seem to fix my problem. If I look at the wireless network connection in control panel it says I'm getting 216 Mbps, but that's obviously not the case.
In a practical test, I downloaded the same game from steam on my MacBook and my new PC. The new PC took 4-5 times longer.
Does anyone have any thoughts? I'm a lifelong Mac user and I've only recently begun to use a windows machine in my daily life, so is there just something about setting up a wireless connection with windows that I don't know? Or are there other things I can do to diagnose my problem? Thanks in advance.
PC Specs:
Windows 7 64 bit
MoBo: Asus z97 A
CPU: Intel core i7 4790k
Cooler: Noctua NH-D14
GPU: 2x EVGA GTX 780
SSD: Samsung 240 Evo
PSU: EVGA supernova 1000 P2
Case: CM storm stryker
https://linustechtips.com/topic/208396-wifi-card-problem-with-new-pc/
Did you install the newest drivers?
TP-Link is crap :/
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
