So heres a build i've been working on for a bit now. (About 2 or 3 months of planning.) The LinusTechTips community has helped me before so I ask for you to help me once more.
I plan on using this for Gaming and possibly Editing,Recording,And streaming in the future.
I want to play alot of games. Like Battlefield and Counter strike and other games coming soon. Like the "The Crew."
Hers the build. http://pcpartpicker.com/p/m9FzXL
So what do you guys think?
(Sorry for any grammar or spelling mistakes.)
https://linustechtips.com/topic/207592-project-orion/
Get a 4790k instead.
I'd also go for an H440 or Enthoo Pro instead of the R4.
I'm assuming the editing/streaming/rendering you're going to do benefits from Cuda/Shadow play/Gamestream. If it doesn't, then go for a Sapphire Tri-X R9 290. If you do actually need Nvidia, I would personally go for a 780 before I spend money on fans.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/207592-project-orion/#findComment-2816123
inb4 people bash Arctic Silver 5
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/207592-project-orion/#findComment-2816125
Which resolution will u play games at?
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
https://linustechtips.com/topic/207592-project-orion/#findComment-2816126
https://linustechtips.com/topic/207592-project-orion/#findComment-2816134
I like the 770 and i plan on doing a 3 screen set-up. I also like the r4 alot more the the H440 (Because i'm werid :3)
https://linustechtips.com/topic/207592-project-orion/#findComment-2816144
@Wrightbk,
I would suggest the 500MHz faster i7-4790K cpu on a motherboard that has on-board WiFi and Bluetooth.
The Asus Z97 motherboards have a heatsink that protrudes past the edge of the motherboard. The H100i is a tight fit in an R4 in any case, and this might cause additional issues. If you wish to keep the R4, it is a nice case after all, then go with something like the H80i.
AMD gpu are a better value at the moment. I would suggest an R9 290X instead of the GTX 780, it is just a few dollars more.
The fans are, IMO an utter waste. If stock fans are not good enough, buy a better case and/or cooler.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($319.99 @ NCIX US)
CPU Cooler: Corsair H80i 77.0 CFM Liquid CPU Cooler  ($87.74 @ Amazon)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste  ($6.70 @ Amazon)
Motherboard: Asus Z97-PRO(Wi-Fi ac) ATX LGA1150 Motherboard  ($198.98 @ SuperBiiz)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($82.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($118.99 @ Amazon)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($99.00 @ Amazon)
Video Card: Gigabyte Radeon R9 290X 4GB WINDFORCE Video Card  ($513.98 @ SuperBiiz)
Case: Fractal Design Define R4 Blackout with Window ATX Mid Tower Case  ($98.16 @ Mwave)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.98 @ OutletPC)
Total: $1646.50
Generated by PCPartPicker 2014-08-31 14:33 EDT-0400
https://linustechtips.com/topic/207592-project-orion/#findComment-2816337
http://pcpartpicker.com/p/B8w9wP
this should work on triple 1080...
https://linustechtips.com/topic/207592-project-orion/#findComment-2820569
