ditch the sound card get a better gpu, like a 770 2gb or 280x
drop the 3 8gb stick
and use that cask to get a good cpu cooler so you can overclock a little bit
Yep do this^
Soundcards really arn't worth it and alot of the time you wont hear a difference.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/207519-decent-first-rig/#findComment-2815395
- I would recommend getting a 990FW motherboard with the FX-8350 over 970
- Ditch the 8GB kit
- Ditch the sound card
- get the CS550M instead for semi-modular and an overall stronger PSU
- With the saved money with the memory/sound card I recommend getting either an R9 280 or 280x
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/207519-decent-first-rig/#findComment-2815431
CPU: AMD FX-8320 3.5GHz 8-Core Processor  (£96.40 @ Aria PC)
Motherboard: MSI 970A-G43 ATX AM3+ Motherboard  (£45.80 @ Amazon UK)
Memory: Crucial 16GB (2 x 8GB) DDR3-1600 Memory  (£110.34 @ Amazon UK)
Video Card: Sapphire Radeon R9 280X 3GB Vapor-X Video Card  (£234.67 @ More Computers)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  (£31.55 @ Aria PC)
Monitor: AOC E2460SD 60Hz 24.0" Monitor  (£107.00 @ Ebuyer)
Sound Card: Asus Xonar D1 24-bit 192 KHz Sound Card  (£36.18 @ Ebuyer)
Wireless Network Adapter: Asus PCE-N53 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  (£26.98 @ Amazon UK)
Total: £774.07
Generated by PCPartPicker 2014-08-31 17:21 BST+0100
Cheaper and better
https://linustechtips.com/topic/207519-decent-first-rig/#findComment-2815479
This is better
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£24.86 @ CCL Computers)
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard  (£64.68 @ Amazon UK)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  (£73.79 @ Amazon UK)
Video Card: Gigabyte Radeon R9 280X 3GB WINDFORCE Video Card  (£201.00 @ Amazon UK)
Case: Corsair 200R ATX Mid Tower Case  (£43.19 @ Aria PC)
Total: £809.49
Generated by PCPartPicker 2014-08-31 17:36 BST+0100
https://linustechtips.com/topic/207519-decent-first-rig/#findComment-2815589
