Hello, im currently doing my build.. and the mobo wont be level on the side of the case.. its a mid tower case from thermaltake. Why is that?
Did you install the brass standoff screws in the correct positions?
"You have got to be the biggest asshole on this forum..."
-GingerbreadPK
sudo rm -rf /
https://linustechtips.com/topic/207270-mobo-not-fitting/#findComment-2812147
Could you add a picture of two to show us what it is you mean?
https://linustechtips.com/topic/207270-mobo-not-fitting/#findComment-2812155
i dont have a phone on me... skype could work
Most likely the stock IO shield. Replace it with the one that came with your motherboard.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/207270-mobo-not-fitting/#findComment-2812249
Install I/O shield, push mobo into I/O shield and screw first screw. Remember to isntall standoffs first. After one screw you can move mobo around so your will align other screws.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/207270-mobo-not-fitting/#findComment-2815399
