it can be AMD Or Intel (overclockable)
atleast 8 GB of Ram (preferably duel channel)
No HDD or OS (already have those)
no Peripherals (already have them)
mid tower case
good fans to go on Front, Rear and top. bottom could be added but less of a need for me.
Nvidia preferd GPU
Trying to keep it under $760 Canadian without shipping. i will order from Canada computers to a local retail for the free shipping.
going to be used for After effects rendering, cinema 4D renders and boujou Motion tracking aswell as medium gaming.
Thanks for reading and giving Input.
EDIT: could be air or water cooling.
Personally i would like a blue theme if possible
https://linustechtips.com/topic/207262-need-help-choosing-components/
mid tower case that im going to be able to keep the side panel completely off for maximum airflow.
Nvidia preferd GPU
What will the system be used for? Why does the side have to be kept off?
i have edited the post for what its going to be used for. the side panel will be off mainly because i just want to look at the beauty and so i can get more airflow into the case.
On a decent case with decent cooling keeping the side panel off is actually worse for cooling than keeping it on, the airflow design is meant to create an air tunnel that feeds the coldest air available on the environment to heatsinks and internal fans, and then roll all that heated air out as soon as possible. With the side panel off, you create a lot of air traps inside of the case where there is no flow, and hot components that need fresh air (CPU cooler) can't dump heat as fast as it needs to.
ok i see that helps alot, thanks.
A nice size window to admire the build :) . A bit over budget :( .
CPU: Intel Core i5-4570 3.2GHz Quad-Core Processor  ($199.99 @ Memory Express)
Motherboard: Gigabyte GA-H97M-HD3 Micro ATX LGA1150 Motherboard  ($94.99 @ NCIX)
Memory: Kingston Black Series 8GB (2 x 4GB) DDR3-1600 Memory  ($79.99 @ Memory Express)
Video Card: PNY GeForce GTX 760 2GB Enthusiast Edition Video Card  ($257.99 @ Amazon Canada)
Case: Corsair 350D Window MicroATX Mid Tower Case  ($100.31 @ DirectCanada)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ Memory Express)
Total: $793.26
Generated by PCPartPicker 2014-08-31 00:11 EDT-0400
Total: $793.26
personally id rather have a overcloackable ATX form factor build in case i choose to go sli in the future. thank you though
the case and the i5 i could go fx-series
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($169.25 @ Vuugo)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.79 @ DirectCanada)
Motherboard: MSI 990FXA-GD65 ATX AM3+ Motherboard  ($119.99 @ Amazon Canada)
Case: BitFenix Merc Beta (Black) ATX Mid Tower Case  ($19.99 @ NCIX)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($64.98 @ Amazon Canada)
Total: $741.98
Generated by PCPartPicker 2014-08-31 01:53 EDT-0400
