I need A case and PSU
Go to solution Solved by ForsakenLive,
But i dont like how the case looks... Can you help me or find me a cool looking one....
It's not about the looks, it's about the internal layout and materials used. It can look good, but if you can barely cable manage, can't keep the case properly clean (lack of dust filters/ needed removal weak plastic front panel), can't fit everything nice and easy, can't install larger air coolers, and can't add proper cooling (case fans etc) then it's a crappy case, not to mention proper build quality on front panel connectors and construction, and loose rivets/screws/panels that vibrate when the PC is on.
I don't know how that Cougar case is, it might be actually good, but by the looks of it, it's a typical low end case with all problems listed above, and it seems to only have room for 1 120mm fan on the front, you should aim for 2.
Usually, for budget ATX builds I recommend the Source series from NZXT which are pretty nice. The Source 220 and Elite 210 are pretty impressive, decent quality, with many features and very sleek looks. If you want something more flashy you can check the Corsair 230T, Corsair Spec 01 and Spec 02.
Hi
This is my build...
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($129.00 @
Video Card: XFX Radeon R9 270X 2GB Double Dissipation Video Card ($219.00 @ PCCaseGear)
Power Supply: I WANT ONE THATS MODULAR AND THATS FITS MY NEEDS
Case Fan: I NEED CHEAP GOOD ONES
Tower: Cougar Volant Black Mid Tower ($49.00) Or Something REALLY GOOD AND COOL (as in design)
Motherboard; ASRock 970-PRO3 R2.0 Motherboard ($89.00)
Ram: Kingston Hyper X DDR3 2x4. ($90.00)
If you have anything thats better than any of these and still would fit my budget be welcome to help
My budget is $650
Do not take life too seriously. You will never get out of it alive.
        :o
https://linustechtips.com/topic/207237-i-need-a-case-and-psu/
My watts will at least be 500W so try to make it 500 or 550, 600 if its the last or best option....
        :o
https://linustechtips.com/topic/207237-i-need-a-case-and-psu/#findComment-2811733
        :o
https://linustechtips.com/topic/207237-i-need-a-case-and-psu/#findComment-2811740
Have you thought about going with the pentium k and a overclockable h97 board
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
https://linustechtips.com/topic/207237-i-need-a-case-and-psu/#findComment-2811792
you can get a r9 280 on newegg for cheaper than that 270x
a corsair cx500m if you want a modular psu.
case? well thats personal preference i like sleek cases so you might no want my suggestions
and just an FYI you might need a hard drive
I live in australia, and the harddrive i have under controll, can you give me a couple of really cool or sleep suggestions...?
And you link me were i can find that better card, remember i live in australia
        :o
https://linustechtips.com/topic/207237-i-need-a-case-and-psu/#findComment-2811799
Cougar are good with fans, not much else.
The Corsair CS500M would probably be the best PSU choice, decent quality and fairly low cost.
Can you link your preferred retailers website? Will be easier finding you a case that way. And perhaps defining "cool" would be helpful.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/207237-i-need-a-case-and-psu/#findComment-2811812
https://linustechtips.com/topic/207237-i-need-a-case-and-psu/#findComment-2811837
What about this? AeroCool Strike-X GT Gaming Tower Cases
        :o
https://linustechtips.com/topic/207237-i-need-a-case-and-psu/#findComment-2811897
Lets just make it the best case possible....
I would think you can use
http://au.pcpartpicker.com/
        :o
https://linustechtips.com/topic/207237-i-need-a-case-and-psu/#findComment-2812057
I think the top three budget friendly ATX cases I would recommend are the Corsair SPEC-01 (Also a 02 & 03), Bitfenix NEOS and Cooler Master N400 (N600 is a little bit more and a has a window if you want that).
https://linustechtips.com/topic/207237-i-need-a-case-and-psu/#findComment-2812105
