Making wireless wired
Solved by Deddie,
Ok, that's cool. But can you disable the wifi module? Because I don't want the interference
Thx I'll definitely bookmark that :)
Yes there's a switch on the back of it to either use it as a wifi-extender or as a mediabridge (wireless to wired).
But it would be cheaper to get an old router and put dd-wrt on it.
Issac Zachary ·
Posted in Troubleshooting2 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0
play_circle_filled
Latest From ShortCircuit:
