I'm not quite sure if this is a problem with afterburner or the gpu to begin with. Please take your time, I'd really appreciate the help, I can't even use my PC at this point.
Okay I'm posting this topic before going to bed hoping I'll be able to fix it with the helpful comments. I'm posting a few pictures because youtube wasn't logging in so I couldn't upload. Basically, I reinstalled my drivers etc for my gpu and I folded for a couple of minutes. After that the uefi dualbios showed up asking me the standard 3 things such as boot with optimized defaults etc. Nothing going wrong at this point.
I was having trouble getting a decent PPD rate while folding, and I decided to reset my overclocking settings on msi afterburner by pressing 'reset'. Suddenly insanely big numbers showed up everywhere on afterburner. Over a 300k at voltage offset, core clock offset etc... I tried pressing reset again, it still didn't remove the big numbers. I tried closing afterburner, but my PC just shuts down instantly. I can't do anything on my computer after rebooting, My screen will just turn blue after logging in. Here are some pictures
Pic1: booting up from bios
Pic2: logging in, everything going fine here
Pic3: going well, for a few seconds
Pic4: the blue screen (not a bsod, but you probably figured that out already)
https://linustechtips.com/topic/207172-gpu-problem-help-please/
Try onboard video, uninstall afterburner, go back to your gpu and see if that changes anything?
Sadly this didn't work, it gave me bsods instead
Edit: okay im on now but I cant delete msi and it's using 28% of my cpu but it's not showing up in my taskbar. Can't close it with task manager either
https://linustechtips.com/topic/207172-gpu-problem-help-please/#findComment-2813829
Sadly this didn't work, it gave me bsods instead Edit: okay im on now but I cant delete msi and it's using 28% of my cpu but it's not showing up in my taskbar. Can't close it with task manager either
Even trying to kill the process won't work either?
https://linustechtips.com/topic/207172-gpu-problem-help-please/#findComment-2813846
Uh oh. Does it give you the option before Windows boots to start normally?
Plot twist
I held the 'reset' button or whatever that is next to the normal on/off switch and suddenly I heard my cpu coolers rpm going up, while it was already running, and it worked. It allowed me to uninstall afterburner and it's all working as intended now :D thanks for the help man!
https://linustechtips.com/topic/207172-gpu-problem-help-please/#findComment-2814150
I hope it's not broken now. D: Do you by chance have a second desktop you can plug the hard drive in to and manually delete Afterburner?
The only problem now is figure out where this awful squeeking noice is coming from. I think it's the gpu coil whining but I'm not quite sure
Edit: @AlwaysFSX , Lol my PC started folding, that's why everything was getting so hot.
https://linustechtips.com/topic/207172-gpu-problem-help-please/#findComment-2814155
.....wow
Glad it works, any problems left?
https://linustechtips.com/topic/207172-gpu-problem-help-please/#findComment-2817944
