C++ Program Help
Go to solution Solved by ThreePinkApples,
Try changing the name of count, there could be something in std that uses the same name, therefore it is ambiguous
I am trying to make a program that will let one user enter a name and the other player no knowing the name will hav to guess it. I have written this program before, but in a different language. I am getting the errors saying my variables are ambiguous and that the operators I'm using don't exist. Thanks for the help, I don't think it should be too hard to solve.
#include <iostream>using namespace std;string name;string guess;int count = 0;int main() {	cout << "Enter a name for the other player to guess";	cin >> name;	system("cls");	while (count < 10) {		cout << "Enter your guess for the name";		cin >> guess;		if (guess == name) {			cout << "Congratulations you guessed the name, without cheating...!";			break;		}		else {			count ++;		}	}	return 0;}
https://linustechtips.com/topic/206395-c-program-help/
If I leave out the system("cls"); line, it compiles fine for me and
works (compiler: g++, using Linux)
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/206395-c-program-help/#findComment-2801154
Damnit Linux! Always being better than windows. I'm using VS Express and I'm still getting errors without that line :(
Errors:
Error	1	error C2679: binary '>>' : no operator found which takes a right-hand operand of type 'std::string' (or there is no acceptable conversion)	c:\users\mike\documents\visual studio 2013\projects\guessing game\guessing game\source.cpp	11	1	Guessing GameError	2	error C2872: 'count' : ambiguous symbol	c:\users\mike\documents\visual studio 2013\projects\guessing game\guessing game\source.cpp	12	1	Guessing GameError	3	error C2679: binary '>>' : no operator found which takes a right-hand operand of type 'std::string' (or there is no acceptable conversion)	c:\users\mike\documents\visual studio 2013\projects\guessing game\guessing game\source.cpp	14	1	Guessing GameError	4	error C2872: 'count' : ambiguous symbol	c:\users\mike\documents\visual studio 2013\projects\guessing game\guessing game\source.cpp	20	1	Guessing Game	5	IntelliSense: no operator ">>" matches these operands            operand types are: std::istream >> std::string	c:\Users\Mike\Documents\Visual Studio 2013\Projects\Guessing Game\Guessing Game\Source.cpp	11	6	Guessing Game	6	IntelliSense: "count" is ambiguous	c:\Users\Mike\Documents\Visual Studio 2013\Projects\Guessing Game\Guessing Game\Source.cpp	12	9	Guessing Game	7	IntelliSense: no operator ">>" matches these operands            operand types are: std::istream >> std::string	c:\Users\Mike\Documents\Visual Studio 2013\Projects\Guessing Game\Guessing Game\Source.cpp	14	7	Guessing Game	8	IntelliSense: "count" is ambiguous	c:\Users\Mike\Documents\Visual Studio 2013\Projects\Guessing Game\Guessing Game\Source.cpp	20	4	Guessing Game
https://linustechtips.com/topic/206395-c-program-help/#findComment-2801202
Try a cin.ignore() after you have cleared the screen. No guarantee it will work, I just have a suspicion
EDIT: OH, you need #include <string> (it helped alot when you posted the errors )
Ryzen 7 5800X     Corsair H115i Platinum     ASUS ROG Crosshair VIII Hero (Wi-Fi)     G.Skill Trident Z 3600CL16 (@3800MHzCL16 and other tweaked timings)
MSI RTX 3080 Gaming X Trio    Corsair HX850     WD Black SN850 1TB     Samsung 970 EVO Plus 1TB     Samsung 840 EVO 500GB     Acer XB271HU 27" 1440p 165hz G-Sync     ASUS ProArt PA278QV     LG C8 55"     Phanteks Enthoo Evolv X Glass     Logitech G915      Logitech MX Vertical      Steelseries Arctis 7 Wireless 2019      Windows 10 Pro x64
https://linustechtips.com/topic/206395-c-program-help/#findComment-2801203
Thanks that removed a few errors, count being ambiguous however remains.
Errors:
Error	1	error C2872: 'count' : ambiguous symbol	c:\users\mike\documents\visual studio 2013\projects\guessing game\guessing game\source.cpp	13	1	Guessing GameError	2	error C2872: 'count' : ambiguous symbol	c:\users\mike\documents\visual studio 2013\projects\guessing game\guessing game\source.cpp	21	1	Guessing Game	3	IntelliSense: "count" is ambiguous	c:\Users\Mike\Documents\Visual Studio 2013\Projects\Guessing Game\Guessing Game\Source.cpp	13	9	Guessing Game	4	IntelliSense: "count" is ambiguous	c:\Users\Mike\Documents\Visual Studio 2013\Projects\Guessing Game\Guessing Game\Source.cpp	21	4	Guessing Game
https://linustechtips.com/topic/206395-c-program-help/#findComment-2801233
https://linustechtips.com/topic/206395-c-program-help/#findComment-2801251
Thanks I wouldn't have though about changing the variables name. I guess that is used as a variable in Visual Studio or Windows. Thanks again :)
Now I am a total C++ master!
https://linustechtips.com/topic/206395-c-program-help/#findComment-2801338
Started C++ two weeks ago myself, and I love it : D
https://linustechtips.com/topic/206395-c-program-help/#findComment-2801344
Oh, I am attending an University here in Norway and the C++ class is this semester (5. semester of Computer Engineering).
I have just made some small simple programs as hand-ins for the class. Also started working on Project Euler in C++ just to get a little more feeling about it
I don't really know precisely what I like about it, it might just be me sick and tired of C# (had that last semester) :P
https://linustechtips.com/topic/206395-c-program-help/#findComment-2801432
Cool, I'm planning to do computer sciences as well, but in Canada, even though I'd love to have the internet speed in norway :P
I have bookmarked Project Euler as well :)
Ya I used to use Turing an old language they taught in my highschool and it wasn't good enough so I have now moved onto bigger and better things. finally
https://linustechtips.com/topic/206395-c-program-help/#findComment-2801500
#include <iostream>using namespace std;int main() {    string name;string guess;int count = 0;	cout << "Enter a name for the other player to guess";	cin >> name;	while (count < 10) {		cout << "Enter your guess for the name";		cin >> guess;		if (guess == name) {			cout << "Congratulations you guessed the name, without cheating...!";			break;		}		else {			count ++;		}	}	return 0;}
dont define variables outside of the main function. when i put the var's in the main function it compiled fine. EDIT: removing the system("cls"); fixed the problem. i compiled using code blocks so yeaa it was on windows
CPU: i7 4770k@4.3Ghz GPU: GTX 780ti Motherboard: ROG maximus vi formula PSU: Evga supernova 1000w Platinum
Case: NZXT Switch 810 Memory: g.skill ripjaws X Cooler: Corsair h100i(getting custom loop when i get money next) Storage: Samsung 840 evo 250gb Keyboard: Corsair K95 Mouse: SteelSeries Rival
https://linustechtips.com/topic/206395-c-program-help/#findComment-2801558
Oh thanks I didn't know that.
https://linustechtips.com/topic/206395-c-program-help/#findComment-2801614
-snip-
this is because of variable shadowing: if there are two scopes, the first containing the second, each scope can have its own definition of a variable with the same name. if you name the variable, you're referring to the inner-most you can find in the current scope
example:
#include <iostream> int main(){          int i = 1;          {                    int i = 3;                    std::cout << "this is going to be 3: " << i << std::endl;                    i = 10; // this vale is writte to the inner-most i, which is just about to be destroyed because the scope is ending          }           std::cout << "this is going to be 1: " << i << std::endl;}
speaking about your code:
using namespace std; // import everything from std:: into the current scope. including std::count (http://www.cplusplus.com/reference/algorithm/count/) which is now accessible via its name, without namespace prefix int count = 0; // count already exists in the current scope, so creating a new one is ambiguous int main(){          count ++; // which one?}
using namespace std; // import std:: in this outer scope int main(){          int count = 0; // shadowing: count is declared in a different scope (the scope of main())           count ++; // refers to the inner-most declaration of count (the one local to main())}
https://linustechtips.com/topic/206395-c-program-help/#findComment-2801966
example:
Thanks for clearing things up. I knew using namespaces imported the whole file, but I didn't know you could have different variables the the same name as long as they're in different scopes. :D
https://linustechtips.com/topic/206395-c-program-help/#findComment-2802220
