i just  got recently introduced to the ::before and ::after pseudo elements and did some tinkering.
Why doesn't this work?
I have this code
HTML
<div class="box"></div>.
CSS
.box::after
  content:"";
  background-color:blue;
  height:150px;
  width:150px;
\why can't i see the box? it only appears when i put content in it and it doesn't even get height and width values just the background-color.
but why does this work with normal css
like this
.box
height:150px;
width:150px;
can someone explain this to me?
https://linustechtips.com/topic/206206-pseudo-elements-help/
the problem should be this:
the square you're inserting ::after is just pure text (a text node), so it behaves like is an inline element
you can't define the height and width of inline elements, because of what they are (they just need to fit in the document flow)
the solution is to set display: block for the ::after element
your workaround works because setting position: absolute automatically sets display: block, because the element is taken out of the document flow
one little thing: ::after is a pseudo-selector, not a pseudo-element :) edit: no, i'm wrong, and dumb
edit again: looks like the ::after element is inline by definition, as you can read on MDN
https://linustechtips.com/topic/206206-pseudo-elements-help/#findComment-2798899
