Overclocking Help
Solved by LogicalDrm,
I'm a newbie to all this, so should I just try tightening it down, or take it off and reapply paste?
Try first tighten and if that doesn't help, take it off and redo whole thing. Screws should so tight that you can't turn them by hand anymore. If you happen to be strong with hands, don't go over threads. You can always test how tight they can be without using mobo.
Xxu ·
Posted in Servers, NAS, and Home Lab0 -
3
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Posted in Servers, NAS, and Home Lab3 -
Sveeno ·
Posted in LTT Releases8
play_circle_filled
Latest From ShortCircuit:
