CPU Intel Core i5-4690K 3.5GHz Quad-Core £164.00 CPU Cooler Noctua NH-D15 82.5 CFM £72.14 Motherboard ASRock Z97 Extreme3 ATX LGA1150 £72.84 Memory Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-2133 £70.56 Storage Western Digital Caviar Green 1TB 3.5" 5400RPM £57.00 Video Card MSI Radeon R9 280 3GB TWIN FROZR £161.10 Case Zalman Z11 Plus ATX Mid Tower £47.99 Power Supply EVGA 650W ATX12V / EPS12V £60.88 Operating System Microsoft Windows 8.1 (OEM) (64-bit)
£79.74
Total:  £786.25
Will this go in the case
https://linustechtips.com/topic/205794-never-built-a-computer-before-so-need-help/
£79.74
Total:  £786.25
Looks good to me.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
In the future buddy I would recommend using pcpartpicker.com as they will tell you if your parts are compatible. It will also make you post smaller as you can just link your build to us then.
As everyone else has sad it looks good.
£79.74
Total:  £786.25
The WD Blue is a better HDD.
https://uk.pcpartpicker.com/part/western-digital-internal-hard-drive-wd10ezex
With the £20 savings swap the psu for this one. It fits ok according to pcpartpicker. The EVGA NEX is not that great. The Superflower is much better.
https://uk.pcpartpicker.com/part/super-flower-power-supply-sf650f14mg
The WD Green are excellent drives, but they are tested and recommended for secondary storage units or backups drives. So, depending on what exactly are you going to use the computer for, I could recommend you these drives:
WD Black is made for fast performance, gaming purposes and heavy programming and has 5 years limited warranty. The other one is the WD Blue hard drive, which is designed for everyday computing in particular.
If you want you may check them at these links:
Hope this helps.
If this post helped you, please like and choose it as a best answer.   :)
http://www.wdc.com/en/
