Will it fit?
Go to solution Solved by nanowatt,
It will
Maximum GPU Length
290mm
Maximum CPU Cooler Height
95mm
Maximum PSU Length
180mm
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/205707-will-it-fit/#findComment-2791859
should easily fit although i would use a reference blower fan design in that case.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/205707-will-it-fit/#findComment-2791878
