My son is looking to build his own gaming computer and I need help choosing a power supply.
I am looking at purchasing the following UK Only:-
CPU: AMD FX8350 Black Edition 8 Core Processor
GPU: XFX Radeon HD 7850 DD Edition Graphics Card (2GB, GDDR5)
Motherboard: Asus Sabertooth 990FX R2.0
RAM: Corsair CMY8GX3M2B2133C9R Vengeance Pro Series 8GB
Case: Zalman Z9 Plus Midi Tower Case - Black
PSU: Corsair CP-9020078-UK Builder Series 750W CS750M ATX/EPS Semi-Modular 80 Plus Gold Power Supply Unit
OS: Windows 8 64bit
Or does anyone have any recommendations staying within the £600 - £700 (maximum) price range preferably
https://linustechtips.com/topic/205672-how-many-watts-do-i-need/
There is no way you would be using that much power with that build. Save some money and go with a lower wattage one :D other then that it looks good
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/205672-how-many-watts-do-i-need/#findComment-2791551
OS: Windows 8 64bit
Is your budget just for the parts listed ? Or do you need the tower and everything inside for £600-£700?
https://linustechtips.com/topic/205672-how-many-watts-do-i-need/#findComment-2791626
