Hello forums,
I need a little help with Grok.
I'm really not sure what I'm suppose to do for this question.
I know we're suppose to use "while" and times the input by 2 until it reaches 7,000,000,000. How how do I do this?
This is what I have at the moment:
alpha = int(input("Number of initial customers:"))
years = (alpha * 2)
while years == 7000000000:
This is what the program is suppose to do:
For a given number of initial customers, write a program to calculate how many years it will take to have everyone on the planet as a customer, assuming they continue to double each year. As an estimate, let's say the current human population is 7,000,000,000.
Your program should work like this:
Number of initial customers: 2
Number of years: 32
Here is another example:
Number of initial customers: 42
Number of years: 28
Your answer should be in whole years. For instance, if the answer is 1 year, then the number of customers after doubling once is greater than 7,000,000,000.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/205530-python-question-basic/
years = 0
while alpha <= 7000000000:
  years = years + 1
  alpha = (alpha*2)
print 'Number of years:', years
i am not a native speaker of the english language
[spoiler=My Rig: ]CPU: i7-3770k@Stock | Ram: 3x4GB@1600Mhz | Graka: 660TI@Stock | Storage: 250GB 840Evo, 1x1TB,2x2TB,2x640GB,1x500GB (JBOD) + NAS: DLINK DNS-320 2x3TB Raid1
https://linustechtips.com/topic/205530-python-question-basic/#findComment-2790543
years = 0
  years = years + 1
  alpha = (alpha*2)
Thank you so much.
The only problem, is it says when inputing 13671875
do this.
Testing a case where the customers double to exactly 7000000000. Your submission did not produce the correct output. Your program output:
Number of initial customers:13671875
Number of years: 10
when it was meant to output:
Number of initial customers: 13671875
Number of years: 9
https://linustechtips.com/topic/205530-python-question-basic/#findComment-2790652
Thank you so much.
do this.
Number of years: 10
Number of years: 9
well "<=" means "equal or less than"
guess what "<" means.
years = 0
  years = years + 1
  alpha = (alpha*2)
don't give full solutions to problems. this won' help the OP after all ...
Mini-Desktop: NCASE M1 Build Log
Mini-Server: M350 Build Log
https://linustechtips.com/topic/205530-python-question-basic/#findComment-2790724
