So im trying to learn Python and im using 2.7 becasue my Python videos use that and its working and so I am trying to write my second little program its a calculator which takes integer input from the user and chooses a function heres my shot at it and it works:
num1 = input("Enter first number")
input("Pick a function add,subtract,divide or multiply")
num2 = input("Enter second number")
so this ^ works it does what its supposed to takes the input but the function part isnt exactly there as I am struggling with that so I want to ask is there a way for example when the User inputs the function Add I want the code to recognise that the User has entered that function and carry it out as a normal calculator does, don't ask why I'm doing a calculator I just want to learn thanks guys
https://linustechtips.com/topic/205431-need-help-in-python-27/
num1 = input("Enter first number") x=input("Pick a function add,subtract,divide or multiply") num2 = input("Enter second number") if x=="add":        answer = num1+num2 print answer
k try this :)
https://linustechtips.com/topic/205431-need-help-in-python-27/#findComment-2788862
k try this :)
that would work execpt its now saying Name Error 'answer' is not deffined
https://linustechtips.com/topic/205431-need-help-in-python-27/#findComment-2788954
oh do
answer=' '
at the start of the code
https://linustechtips.com/topic/205431-need-help-in-python-27/#findComment-2789187
