Ive been using a dirt-cheap $12 PSU for the last couple years, and it provides 450w, enough to power my modern system, (until a year ago, when I had to upgrade to a 650w) which got me thinking, my new power supply was $100 and so, besides power efficiency and modular/non modular preferences, what are the differences. Also, does better power quality effect your fps?
Build: Fx-8120@4.1ghz,  Gtx770@1.0ghz,  16gb Patriot memory,  Cheap case from thermaltake
https://linustechtips.com/topic/20543-difference-between-power-supplies/
nothing to do with fps, higher quality powersuppies have to deal with energy bills and the cleanliness of the power going to your componets
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
Lower end power supplies usually have a tendency to have more power ripple. This means it will tearing more on the components and a cheaper powersupplie will not perform at 100% for as long as a quality powersupplie.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
Other differences in power supplies can also be multi-rail or single-rail. And no, power supplies do not affect gaming performance whatsoever.
Power supplies don't affect your fps but it affects your system overall. If you get a generic psu, it is likely to degrade and it will lose its power and the loss of power would damage your computer if the power supply isn't giving enough power to power your components.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
ok i also have a question. why do people harp on "overkill" ik it isnt as efficient...but SO WHAT?  ok they use 20 more watts than a more efficient powersupply.....but is that it? is that all?!! those are my questions :D thanks for your replys  :)
i mean what if in 3-5 years they discover a new energy source and power is dirt cheap and  the manufacturers make power hungry processors and cards? (this is just hypothetical ahah)
More efficient PSU also means less electricity wasted in the form of heat. Which means less heat output from the PSU.
Thought so
 what i was trying to say is that there are alot of the times sale on some psus that have a higher wattage
also psus most of the time take heat from the bottom and expel it out the back
also a psu is like a case it doesnt really have to change every build one does or it can be compared to RAM (good for 2-3 builds) :)
