Will it fit
Go to solution Solved by SAV1OUR,
BTW Is those screws what i am thinking they are?
pretty sure that's for the cooler
Will hyper 212 evo fit in my motherboard? Will ram be a problem? Screenshots : . BTW Is this a hard process? Just some screws and thats it?
wLkwdyC.jpg?1The backplate.
e2hNSUC.jpg?1
Current cooler -  Zalman CNPS5X
CPU: AMD FX 8350 | GPU: AMD R9 270 Windforce | MOBO: ASRock 990FX Extreme 3 | RAM: Kingston HyperX 8GB | Case: X Predator X1 |CPU COOLER: Hyper T4
NAZIS WILL RISE.
https://linustechtips.com/topic/205037-will-it-fit/
nope everything's fine, as for installation just follow the guide
Specs
https://linustechtips.com/topic/205037-will-it-fit/#findComment-2783488
Your motherboard is AM3+ correct? Then yes.
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/205037-will-it-fit/#findComment-2783490
What guide? will there be a manual with the cooler? And i am really new to this, can I get lost ? Lol..
NAZIS WILL RISE.
https://linustechtips.com/topic/205037-will-it-fit/#findComment-2783502
There's tons of videos for installation on youtube.
Ryzen 9 5950x | NH-D15 | ROG STRIX X570-F | G.Skill 32GB DDR4 | MSI Ventus RTX 3080 | WD Black SN850 1TB PCIe 4 | Samsung 850 EVO + 860 EVO 1TB | Corsair 5000D Airflow
Dell S3422DWG | Dell S2721DGF | Corsair K70 RGB Keyboard | Logitech G502 Lightspeed | ATH-R70x
https://linustechtips.com/topic/205037-will-it-fit/#findComment-2783510
there's a manual with the cooler
Specs
https://linustechtips.com/topic/205037-will-it-fit/#findComment-2783528
"Supports CPU cooler max. height up to 158mm." My case says.
NAZIS WILL RISE.
https://linustechtips.com/topic/205037-will-it-fit/#findComment-2783529
Thanks.  BTW  - "Supports CPU cooler max. height up to 158mm." My case says.
NAZIS WILL RISE.
https://linustechtips.com/topic/205037-will-it-fit/#findComment-2783532
image.jpg?w=400&c=1
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
https://linustechtips.com/topic/205037-will-it-fit/#findComment-2783536
image.jpg?w=400&c=1
you might wanna get your eye checked out
Specs
https://linustechtips.com/topic/205037-will-it-fit/#findComment-2783546
But they look good too me!
https://linustechtips.com/topic/205037-will-it-fit/#findComment-2783585
you definitely need to get your eyes checked out then if you're able to see yourself
Specs
https://linustechtips.com/topic/205037-will-it-fit/#findComment-2783594
NAZIS WILL RISE.
https://linustechtips.com/topic/205037-will-it-fit/#findComment-2783632
Specs
https://linustechtips.com/topic/205037-will-it-fit/#findComment-2783637
Thanks for all the info man :)
NAZIS WILL RISE.
https://linustechtips.com/topic/205037-will-it-fit/#findComment-2783642
Use PcPartPicker to check compatibility
[spoiler=My PC]
CPU: Intel Core i7 6700K | COOLER: Corsair H105 | MOBO: ASUS Z170i Gaming Pro AC | RAM: Corsair LPX DDR4 16GB 2400MHz | GPU: EVGA GTX 980 Classified | CASE: BitFenix Prodigy | SSD: Samsung 950 Pro 512GB | PSU: XFX XTR 650W [spoiler= Le Other Stuff] Monitor: BenQ XL2411Z | Keyboard: Ozone Strike Pro | Mouse: A4 Tech X7 F4 | MousePad: Ozone
PlayStation 2 | PSP 2000 | Game Boy Color | Nintendo DS Lite | Nintendo 3DS | Wii
Sony Xperia J (Why u so bad D:) | iPod 4th gen | iPhone 4 | Yarvik Xenta 13c (3muchchrome5her)
Pentium B980 | 500GB WD Blue | Intel HD Graphixxx | 4Gegabeytes of REHAM
Current OS: MSX 10.0 ( ͡° ͜ʖ ͡°)Ilikethelennyfaceyouknow( ͡° ͜ʖ ͡°) Windows Password Reset Guide
https://linustechtips.com/topic/205037-will-it-fit/#findComment-2783688
