Hey guys, so i just got a hyper 212 evo to replace my stock heatsink because i wanted it to be quieter and cooler. So i applied it two times before its final application.(As not to apply it wrong) So i go and test my temps with prime 95 and this is what i get.
http://imgur.com/mnUHkXN
This is lower with the 212 evo than i have seen before...is this normal? Not that i'm complaining just suprised. Thanks:)
 CPU: AMD FX-6300     COOLER: Hyper 212 EVO    MOBO: ASUS M5A97 R2.0    RAM: Team Vulcan 8Gb (4Gb x 2) , G-Skill Sniper (4Gb x 2)    PSU: Rosewill HIVE-750w    GPU: ASUS HD 7790 2Gb OC    CASE: NZXT Phantom 410    STORAGE: WD Black 1Tb , Intel 530 120Gb     AUDIO: HyperX Cloud , Sennheiser HD 518 , Audio Technica ATH-M30 , Sennheiser MM30G , Yamaha RX-V361 , Pioneer SP-BS22     PHONE: Samsung Galaxy S7 Edge     PERIPHERALS: Razer BlackWidow Ultimate Classic , Logitech g502 ( Thanks Syntaxvgm <3 )
https://linustechtips.com/topic/204758-hyper-212-evo-temps/
That's obviously reading wrong, unless you're living under LN2. AMD FX CPUs are known for crappy temp readings. Try HWInfo
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/204758-hyper-212-evo-temps/#findComment-2780613
Looks like you got a faulty temp sensor. Use something like HWMonitor and look at what it says for socket temp. Usually the motherboard will also have a CPU temp sensor below it, so you can use that to know how hot it is.
AMD makes cheap POS temp sensors.
https://linustechtips.com/topic/204758-hyper-212-evo-temps/#findComment-2780640
I think they use some algorithms instead of a physical probe on the CPU.
https://linustechtips.com/topic/204758-hyper-212-evo-temps/#findComment-2780665
I don't think you can measure temperature using algorithms. xD
https://linustechtips.com/topic/204758-hyper-212-evo-temps/#findComment-2780693
I'm almost certain that it does. Try to do a quick Google.
https://linustechtips.com/topic/204758-hyper-212-evo-temps/#findComment-2780734
I did. There is no temperature measuring algorithm. What it is though, is that the CPU has a digital sensor that outputs a value, then tht value is decoded by an algorithm to give an accurate temperature reading. And apparently one of those two things doesn't work properly.
https://linustechtips.com/topic/204758-hyper-212-evo-temps/#findComment-2780785
Well yea. You know what I meant. It had something to do with algorithms xD Pardon my ignorance.
https://linustechtips.com/topic/204758-hyper-212-evo-temps/#findComment-2780803
Well the sensor was working really well before i installed the cooler. Is there any way i could have damaged it?
https://linustechtips.com/topic/204758-hyper-212-evo-temps/#findComment-2781021
idk...
maybe it just gave up on life...
https://linustechtips.com/topic/204758-hyper-212-evo-temps/#findComment-2781048
idk...
I downloaded hwinfo and this was what i got.
I hope it seems normal.
http://imgur.com/xh8TAEl
https://linustechtips.com/topic/204758-hyper-212-evo-temps/#findComment-2781078
idk...
Should i be worried about it reading slightly lower temps?
https://linustechtips.com/topic/204758-hyper-212-evo-temps/#findComment-2781428
Yeah. As long as your socket temp is below 65-70C you should be ok for overclocking the CPU.Just don't push it to the max.
https://linustechtips.com/topic/204758-hyper-212-evo-temps/#findComment-2781441
Oh I'm not overclocking it...to much for my taste. But I did go into the bios and it said it was at 39°c. Is that ok?
https://linustechtips.com/topic/204758-hyper-212-evo-temps/#findComment-2781510
Well the bios will tell you the same as any other temperature monitoring software...
I think you should be ok though.
https://linustechtips.com/topic/204758-hyper-212-evo-temps/#findComment-2781529
Ok thanks m8:)
https://linustechtips.com/topic/204758-hyper-212-evo-temps/#findComment-2781554
Ok thanks m8:)
np m8 ;)
https://linustechtips.com/topic/204758-hyper-212-evo-temps/#findComment-2781616
