So earlier this evening my pc was all of a sudden running fairly slow and noticed my RAM usage was higher then normal(65-75%) while just browsing reddit. So I restarted my pc and now it only boots to the asus bios splash screen and then just black screen after that. Ive removed all my RAM sticks and tried booting with one in at a time amd nothing. Also tried plugging my main hdd into my roomates pc to repair os and plugged it back in mine and nothing. Any advice would be greatful
https://linustechtips.com/topic/204344-help-plz/
I cant load the advanced boot screen. The only bios menu I can enter is the asus mobo menu. In the manual it says press f5 as soon as the asus logo appears but that hasn't worked. Every time I boot from my hdd from the asus bios screen it just goes to a black screen afterwards
https://linustechtips.com/topic/204344-help-plz/#findComment-2775032
