https://linustechtips.com/topic/204125-need-help-picking-a-psu/#findComment-2771517
If you don't plan on getting a 2nd GPU, get the Corsair HX850
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/204125-need-help-picking-a-psu/#findComment-2771518
are making a crossfire configuration in the future, because if not you don't need that much wattage
Planned I Hope Someday I Do First Build: CPU: Intel Core i7 5820k CPU Cooler: CM Hyper 212 EVO Mobo: MSI X99S SLI PLUS RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4-2133Mhz Storage: Corsair Force LS 240GB SSD & 2TB WD Green Graphics Card: ASUS GTX 970 4GB Turbo Case: NZXT S340 White PSU: EVGA SuperNOVA NEX 750W 80+ OS: Windows 8.1 64-bit OEM Monitor: AOC i2267Fw 60Hz 22" Monitor
https://linustechtips.com/topic/204125-need-help-picking-a-psu/#findComment-2771525
Neither, evga 750g2
You need like 850w minimum for 2x 290's I would be leaning towards 1000w myself.
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/204125-need-help-picking-a-psu/#findComment-2771534
Wrong, but there is only 1 290.
https://linustechtips.com/topic/204125-need-help-picking-a-psu/#findComment-2771542
Well I'm not lol...What is the point of getting a 750w for 1 card when you can spend a bit more and get a decent 850w that will support CF?
https://linustechtips.com/topic/204125-need-help-picking-a-psu/#findComment-2771561
Do you plan on adding a 2nd R9 290 in the future ? If not then you can drop down to a 550W/650W.
Also are you not adding an aftermarket cpu cooler ?
https://linustechtips.com/topic/204125-need-help-picking-a-psu/#findComment-2771654
IDK atm I'f probably add another one but maybe not im watercooling the gpu and cpu and maybe RAM so idk
https://linustechtips.com/topic/204125-need-help-picking-a-psu/#findComment-2771677
You don't need 850W for a single gpu.
OP asked for a choice between the 2, and the Corsair one had 3 models, the 850W being the best option out of what he put forth to choose from.
https://linustechtips.com/topic/204125-need-help-picking-a-psu/#findComment-2771707
Silence isn't really a factor with those Noctua Industrials lol.
For overclocking with 2x R9 290's we typically recommend 850W. So with a full custom loop overclocking everything as much as possible, 1000W isn't too much overkill. It depends if you're going to add another R9 290.
^ Except the G2 1000W is a good $60 less than the HX1000i. The P2 1000W is nearly $40 cheaper. The P2 1200W is only $6 more than the HX1000i ffs.
The EVGA 1000W currently in your system is the G1, which I can't recommend. The G2 is the one we all rave about because it's awesome. The G1 is new, with few reviews on it.
https://linustechtips.com/topic/204125-need-help-picking-a-psu/#findComment-2771720
Yeah I know, but you said go for an 850W if you don't plan on getting a 2nd GPU which is wrong  :) You could have suggested an alternative lower wattage psu like a 550W/650W.
https://linustechtips.com/topic/204125-need-help-picking-a-psu/#findComment-2771845
I was picking from the 2 options OP put fort you twit.
Yes i could have suggested an alternative, but i chose to pick from the 2 OP has his eyes on.
https://linustechtips.com/topic/204125-need-help-picking-a-psu/#findComment-2771879
I just cant find nff12s on pcpartpicker
https://linustechtips.com/topic/204125-need-help-picking-a-psu/#findComment-2772515
