My profile got corrupt on one of my games and i want to use cheat engine to cheat in the same money i had in the corrupt profile
Cheat engine is not a virus per say.  Most virus scans will say it is though, as it tampers with RAM addresses.
Desktop <dead?>
P8P67-WS/Z77 Extreme4/H61DE-S3. 4x4 Samsung 1600MHz/1x8GB Gskill 1866MHzC9. 750W OCZ ZT/750w Corsair CX. GTX480/Sapphire HD7950 1.05GHz (OC). Adata SP600 256GB x2/SSG 830 128GB/1TB Hatachi Deskstar/3TB Seagate. Windows XP/7Pro, Windows 10 on Test drive. FreeBSD and Fedora on liveboot USB3 drives.
Laptop <Works Beyond Spec>
HP-DM3. Pentium U5400. 2x4GB DDR3 1600MHz (Samsung iirc). Intel HD. 512GB SSD. 8TB USB drive (Western Digital). Coil Wine!!!!!! (Is that a spec?).
it doesnt
its a false positive just turn off AV
also i recommend using trainers instead of cheat engine
well some games don't have trainers that work as well as CE would
Specs
No it doesn't have a virus.
