Camera purchasing help (DSLR, <1000$)
Go to solution Solved by Hulk,
I've gone ahead and purchased the 700D. Thanks for all the help guys! :)
Hello!
I will be buying an entry level DSLR soon and am deciding among these four options. Which of these would be the better for taking high quality photos of nature. I will be using the zoom function a lot, so I would appreciate it if that was kept in mind when making a suggestion. :)
Canon EOS 600D
Canon EOS 700D
Canon EOS 60D
Nikon D5200 (with AF-S 18 - 55 mm VR Kit + Nikon AF-S DX VR Zoom-Nikko)
If you have a better suggestion in the price range of these camera, please share them in the comments.
Thanks! :D
https://linustechtips.com/topic/204008-camera-purchasing-help-dslr-1000/
The 60D all the way. Make sure to get some good lens' to go along with it. And maybe a Flash
It comes with the EF-S 18-135 MM II LENS as a default. Is that good?
For starting off, yes. But I would diffidently invest in a flash, macro lens and a telescopic one too
Thanks for the recommendation! By the way, how should I be comparing the cameras; what makes the 60D better than the other choices?
I just am a big fan of Canon, so im kinda biased. Do get a second opinion doe, try it out in store, to get a feel for what you like
There's alot to think about when buying a new camera.
Have you any lenses already from a certain company/brand?
Have you any experience with dslr before?
You say entry level camera and link 3 mid range ones with the 600D enrty level.
Getting into photography aint cheap, you will have to pay for the field you want to shoot...
Camera body/macro lens for insects/zoom for distance shots/tripod or mono pod/case to carry your camera and lenses/a good memory card or 2, plus maybe some other stuff that takes your fancy.
Then you have post processing software again the best ones aint cheap, and if you do want to PP these need a fairly new operating system and a reasonably specced pc to run smoothly. Oh and nice monitor too (ideally colour calibrated to with something like xrite color monki display or spyder4) because if u do PP on a poo monitor, when you print the colours will be off same thing when you see your pics on another monitor, compared to how you post processed them.
I would get the Nikon 5200 out of the ones you linked as it has more focus points and has more mega pixels so you can crop a bit more in post processing.
Any other cameras to look at? Nikon 3200 or the 3300 stand out off the top of my head.
I also recommend going to your local camera shop to see which camera feels better in your hands.
Have a look at digital photography review website there is a wealth of info over there, they also have a good comparison thingy there too, also helpful forums too.
CPU: I5-4440 / MOBO: Gigabyte GA-Z87-DS3H / RAM: G.Skill ripjaws 2x4GB / Storage: Samsung 840 EVO 128gb SSD, 1TB WD HDD / PSU: Corsair CX500M / Case: Xigmatek Aquila / Monitor: Dell U2414H
The Canon hundreds (eg 600D) and thousands (1000D) are for consumers and the tens (eg 60D) are for enthusiasts and ones that (eg 7D) are for prosumers and pros.
I'd go 60D if it's the one with the 18-135. That lens will do you fine but the 50mm f1.8 is a great secondary lens because of the wide aperture which means you get more background blur than the 18-135 provided you are using f1.8-3.2 on the 50mm. Also you'll want a bag and a tripod.
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
  • 3 weeks later...
I think you can get the Nikon D7100 for less than a thousand now (depending on your location of course)
CPU: Intel Xeon E3-1240 v3 Motherboard: Gigabyte GA-Z87-HD3 RAM: 16 GB GeIL Dragon 1600mhz GPU: Gigabyte Windforce 770OC 2GB Case: Corsair Obsidian 450D Storage: 1TB WD, Blue, 120GB, munch ssd PSU: 600w Corsair
Display: aoc tn something, Dell ips U24..  Keyboard: CM storm quickfire xt Brown switches Mouse: Logitech G502, Pricing: http://pcpartpicker.com/p/8CBWjX
I recommend the D5200 more autofocus points higher resolution but the ISO is not as high but do you need to photograph in low light if so go for the canon 60d check out my detailed post for first D-SLR choice in another post in this section it's called "Photography Buying Guide" my detailed post is on the second page
Do you anything about D-SLR use, if not don't get a mid-pro range get the starter-mid range cameras to get into photography with a D-SLR get used to using one with manual ect checkout the other topic called "Photography Buying Guide" in the same forum thread my post is on the second page has everything you need to know.
Hello!
Canon EOS 600D
Canon EOS 700D
Canon EOS 60D
Thanks! :D
I'll always say that lenses play a bigger role than the body so I suggest to get a "cheap" body (Nikon D5300 - http://www.flipkart.com/nikon-d5300-dslr-camera/p/itmdxhha649whyuf?pid=CAMDR82NFS95MG4K&srno=b_9&ref=f7607b27-4498-410e-860f-5b80f4bc518f) and pair it with some good lenses: Nikon 35mm F1.8 (http://www.flipkart.com/nikon-af-s-dx-nikkor-35-mm-f-1-8g-lens/p/itmcxgeqhjvz8qeb?pid=ACCCXGEQHJVZ8QEB&srno=b_1&ref=c8801f3a-3741-4489-9d57-22bab0a53864) and Nikon 55-200mm VR (http://www.flipkart.com/nikon-af-s-dx-vr-zoom-nikkor-55-200-mm-f-4-5-6g-if-ed-lens/p/itmcx3sgrhsrgthz?pid=ACCCX3SGRHSRGTHZ&srno=b_2&ref=846378ab-d75c-4747-aff3-c226a668d579). Those plus the kit lens should get you up and running. You'll get 2 decent zoom lenses (18-55 and 55-200) and a nice fast prime (35 F1.8) all for less then 60000Rs
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
