Total overkill on the motherboard. You can go much stronger on the graphics card instead, give me a moment to update your build.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/203813-first-build/#findComment-2767291
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($89.99 @ Newegg)
Video Card: MSI Radeon R9 280X 3GB TWIN FROZR Video Card  ($284.99 @ SuperBiiz)
Case: Corsair 300R ATX Mid Tower Case  ($49.99 @ Micro Center)
Total: $832.16
Generated by PCPartPicker 2014-08-25 08:57 EDT-0400
This is $32 over but gives quite a bit more performance, better case (also cheaper), better PSU, better memory and not as much overkill on the motherboard.
https://linustechtips.com/topic/203813-first-build/#findComment-2767307
Total: $832.16
Isn't the motherboard I selected better for when I want to have 2 videocards in the future? I think I will want to upgrade in the future!
https://linustechtips.com/topic/203813-first-build/#findComment-2767333
This motherboard is fine as long as you plan to Crossfire with AMD since that is still supported by this motherboard.
https://linustechtips.com/topic/203813-first-build/#findComment-2767338
I see u live in the netherlands, at the alternate shop you get a free mouse worth 30 euro, and 30 euro cash back if you buy an i5 aswell.. Isnt that a good deal?
https://linustechtips.com/topic/203813-first-build/#findComment-2767357
Just saw the deal. I'm also seeing a €45 cashback when buying a selected intel CPU and an MSI gaming motherboard. Try to find out whether the MSI Z97 Gaming 5 with the I5-4690k falls under that. If it does, go with this combo.
https://linustechtips.com/topic/203813-first-build/#findComment-2767366
It does, but it gives 30 euro instead of 45. You get the 45 with an i7.
So now that I know this i will definiately (or something) get the i5 + that msi mobo. I think ill get the r9 280 non x version to save some more money and maybe upgrade later. what do you think?
https://linustechtips.com/topic/203813-first-build/#findComment-2767380
The 280X is only marginally more expensive than the 280 non-x so I would just go with the 280x.
https://linustechtips.com/topic/203813-first-build/#findComment-2767389
