I have an Intel DZ77BH-55k and am using the onboard ethernet.
When I boot, the internet does not work. My temporary solution (that works, but is VERY annoying and time-consuming) is to uninstall and re-install the drivers after every boot.
I have tried the newest drivers from Intel's site, and the ones that came with the mobo.
Any help is appreciated!
https://linustechtips.com/topic/203366-intel-lan-ethernet-driver-issues/
Use older drivers... worked for me on a Intel NIC
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
Usually, Intel NIC work just fine with the default Windows drivers, only when you need specific features it's better to install the drivers.
Tried the ones that came with the mobo already. I will try some older ones later.
This should shorten your search time :)
https://downloadcenter.intel.com/SearchResult.aspx?lang=&ProductID=3299&ProdId=3299
osu! profile
