EK backplate when not watercooling
Go to solution Solved by ERSCreeper,
Oh ok does this? http://www.pccasegear.com/index.php?main_page=product_info&products_id=25988&cPath=882 also i cant seem to find out if the windforce card has a custom pcb
What I would suggest you do it drop pccasegear a message and ask them since they would be able to confirm it better than I could.
Just wondering whether you can use this http://www.pccasegear.com/index.php?main_page=product_info&products_id=25538&cPath=882 when your not watercooling and whether the windforce 290 uses a reference pcb
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
https://linustechtips.com/topic/202540-ek-backplate-when-not-watercooling/
|| MAELSTROM ||
thanks for your help :)
|| MAELSTROM ||
