Pretty much got a sandisk 32gb usb that doesnt work... as in I can drag files into it
I think because of a format called fat32 which I have no idea about...
Would love some help from the community thanks
Welcome to Linus Tech Tips!
FAT32 has nothing to do with whether the USB has issues or not. Try resetting the partition table using this guide.
http://tech.saoslab.com/post/2013/03/18/cleanup-corrupt-partition-table
"Rawr XD"
https://linustechtips.com/topic/202113-usb-format-problems/#findComment-2740716
Would love some help from the community thanks :)
ps sorry if this is in the wrong sub forum
Depends on the file size. Just format it to NTFS so it supports large files and it will work fine. I run my 8gb in fat32 and 16gb in NTFS. :)
https://linustechtips.com/topic/202113-usb-format-problems/#findComment-2740718
Its not a problem of file size as even a 3mb picture wont copy over, neither will an episode of top gear, will try the guide
https://linustechtips.com/topic/202113-usb-format-problems/#findComment-2740737
