From the wall or to the mobo? Both should be fine afaik.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/201634-mixed-power-cables/#findComment-2734100
It's all good. They are a standard
https://linustechtips.com/topic/201634-mixed-power-cables/#findComment-2734105
My friends pc just died out on him and he gave me his pc to work on. He cant find his power cable for his psu. I was wondering if I could use my power cable and plug it into his psu. Will this cause any issues?
If you are talking about this cable: 1.2m-pc-power-cord-us.jpg
Then yes you are able to use your power cable to plug it into his psu.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/201634-mixed-power-cables/#findComment-2761547
